A few more questions, mostly safety related that I couldn't find answers to in my searches:
1. Removing the galvanized coating. I know you can use sandpaper or muriatic acid (or just don't breathe when brazing!). I hit the brakeline with a sander. Yeah, looks shiny, but I don't know if it's taken the galvanized coating off. Is it enough to just sand it to a shine, or is the coating thicker than that?
Although I'm not 100% on this. The galvanized coating is thin and dull looking once it's shinny it should be off. I sand (w/ dremel or as in vid) to a shine and have had no problems.
2. Is it safe to/do people braze indoors? I'm talking inside my house in the basement over the concrete foundation (using a raised metal slab, not brazing directly on the concrete). I don't have a garage or workshop, and it's too dang cold outside.
I braze inside my garage w/ closed windows and door so typically the same sinario your working in. So I'd call it safe. Just try not to braze around any paper or flamable liquids.
3. Storing MAPP gas. I plan on getting the self-igniting head. I also have a four year old in the house who, while we store everything well out of reach, is very capable of getting into almost all cupboards, etc. I might just lock it away, but I'm curious as to how easily the MAPP gas is ignited with the self-igniting head (i.e., does it have some built in safety features to prevent curious fingers from accidentally igniting it)? Is it better to store partially used gas without the head on it?
I'm also in the same situation. But since I do most everything in the garage the little ones won't go in there while I'm not and have been instructed NOT TO TOUCH anything. But we all know how that goes, I've shown my kids how to use most of my stuff and have given a full safety lecture. (if you touch this the house will blow up and we will all die..LOL)
Best bet is to store it out of reach with the bottle and tourche seperated and in different spots if you are worried they'd get into it.
Also the self igniting torch does lock, but not in a safe way. It will lock the flame in the ON position.
4. Anything special in the way of clothing used while brazing? Obviously no loose shirts, etc., but it doesn't look like you have to go to the extent that you do with welding.
I generally wear the same clothing that I've worn all day. Jeans (slacks on occasion LOL) and T shirt. I do wear a dust mask because of sanding the joints. about 45% of the time I'll wear leather gloves when I know I'll be touching some hot spots more often. but you kinda get use to hold hot tube.
Thanks again. I'm not paranoid, just trying to be as safe as possible.
