Love those new axles on there Ed. Set-up as a roller it looks really good now!
Good luck with the beadlock rings. I talked to several wheel mfg's about it, but I think they all found it a little daunting for bl rings! Can't say I blame them, lots of detail work in there. One option might be to find someone willing to do the CAD work for the design, then pass that on to a wheel mfg.
Hmmm, I thought C.A.C. was CadtoChrome. Oh well, I'm pretty sure it was CadtoChrome.
Sorry, my Bad. Did not realize that C.A.C. is CadToChrome. I've been communicating with Chuck, as well. He seem quite preoccupied the past months.
The K-44 and OG Bruiser/Blazing Blazer axles do have some things in common. Both are composed of housing halves and the axle tube diameter is 10.04mm. With a set of XVD's, I sure look forward to try-out and seeing if the K-44 will manage a decent rock trail same as the RC4WD Black Widow axles without breaking.
Yeah, It was like pulling teeth to get him to make them, even when you are willing to spend the money. I agree with the CAD work issue, once that is done then that is half the work. The other expensive part is the tooling to machine them.
I did have an idea that just might be easier. But it would involve you making a blank. Once you make one out of Delrin and a dremmel, you can have them made out of plastic or Aluminum. By either buying the kit yourself or sending it to someone like Kuatto.
The company is called Alumilite.
http://www.alumilite.com/
CadToChrome and CAC are two completely different people. Ed has C2C products not CAC.
I'm sure you have now seen that the gears in the K44 are the same as the Black Widow axles ;-)
So OG Bruiser axle tubes are also 10mm OD?
Sorry about the C.A.C. vs. C2C thing. Didn't know what I was thinking. On the issue of the axles, I just hope it'd better than pot metal.
Just got an email from a good buddy here, who says he'll do the beadlock rings, wooohooo! "thumbsup"
That's good news. It'll look that much better with the trucker chick rings on there "thumbsup"
siggy what wheels are shown in this photoBeen pondering past few days if Jenny would look nicer if built as a 2.2 instead of a 1.9. Here's a mock-up at 12.5" wheelbase.
Hey Sig, if you end up getting them rims, find out how much to do me up a set. I would love to have some.
