I have center shafts that have a 4mm thread on either side of the yoke, and my axles/tranny output shafts have 2.5mm holes through them. Would it be best to use 2 4mm setscrews from either side that press into the hole of the shaft, or a single setscrew/pin style shaft that screws in from only one side of the yoke and the pin goes straight through the shaft. Usually I would prefer a pin, but in this case the other side of the yoke has a 4mm threaded hole that does not support the 2.5mm pin (the pin just floats in the middle of that hole without touching) Which method would be stronger?
