Clod Gear Ratio
ultralord
Riverside IA
anyone know what the gear ratio is on the clodbuster? Below is what I would like to know
Spur Gear = ?
Trans Ratio = ?
Diff Ratio = ?
All I know is the total gearbox ratio. Tamiya lists this as 30.1 : 1.
If you want to calculate gear ratios for different pinions do this:
30.1 x (13/pinion gear)
The stock clod uses a 13T pinion, so for a 9T pinion:
30.1 x (13/9) = 43.478
Hope this helps.
Clod gearbox:
50/13 X 44/15 X 40/15
the 13 is the pinion, substitute your pinion of choice.
(Or do as grizz said and linearly factor the pinions)
