soze
GREAT video, Dustin! "thumbsup"
Ditto. Is the 4100kv SkyRC motor you're using the 8.5T modified one? I have one that I didn't know what to do with.
Skip to 5:42 For jumping and fast run footage. The rest of the video is just me rambling on in a boring way.
Small update:
I opened-up the front diff with the help of the HPI bevel gear set 103400. It took a bit of machining/dremeling to get the Gmade axles fit the slots in the ‘cheek gears’ the slot is jùst a bit too short. I had to enlarg/lengthen the slot in the gears jùst a tad to make them fit the Gmade axles. (Dang! HPI’s sintered gears are hard!)
I did it because I’m more like a basher than a hard-core crawler. In due time the Gom will get a more potent motor. Probably my k4 8.5t. And high speeds with a front locker makes the whole affair a bit overly tippy. Still needs a rear sway-bar too.
With the HPI gears, and some small rubber rings - left over from the axial exo diffs- around the outgoing shaft opening, and thin tamiya diff washers under the ‘cheek gears’ ( can’t remember the official english name) , the diff is tight enough to be filled with thick diff-oil without leaking it allover the place.
All in all the Gom still climbs admirably, but is a tad more usable at speed. I just like my crawlers/trailers that way.
Anyone else have this kind of wheel wobble in the front?
Everything is tight, nothing seems off.
I'm hoping cva's And possibly aluminum knuckles helps, but id like to fix it before spending $90.
Looks like the bearing and the driveshaft cup is moving.
Yup!
Low quality Ball bearing with not very good tolerances. The inner ring of the bb can tilt for a bit.
It could be the play in the Knuckle Bushings due to the wear out
I think he bought the brass knuckle bushings like I did. Or am I wrong?
I had a crap load of Fast Eddy bearings laying around so I got to use them every where except the transmission.
