Yup I built it and didn't like it. I always form strong opinions and usually quickly. Sometimes they change over time but not too often.
I still don't like this car but I absolutely wanted to. It looked like Gmade had finally made something that looked cool. I have owned every Gmade except the Komodo, all the way back to the MOA clod sized crawler from the mid 2000's.
If this is going to be a slow crawler with a brushed motor, maybe it will be alright. But the diff lockers will blow long before even a stock Axial would. That little locker is ridiculous and the amount of engagement the axle shafts have into is going to make it even worse by focusing the load on a tiny area.
The 2 speed and dig is a pretty impressive thing to throw into a kit for $330 and most of it isn't bad at all other than annoying E-clips but oh well. Then they get to the shift lever and come up with this shitty little slider that runs in a terrible slot design. In the real world with dust, mud and water that is going to go south. Hopefully someone comes up with a lever style design and a redesigned tunnel that goes between the front trans and rear T-case.
The driveshafts are throw-a-ways. Exposed tiny clips on the outside of the U-joint is a joke.
Just like the bomber, this car needed to come with a rear sway bar.
Working on this car will be the worst part. Building it as a kit with the manual in front of you is less convenient than most cars I've built. The number of different length hardware immediately adjacent to each other is what often drives me nuts. I rarely work on my car after the fact with the manual any where in sight, good luck remembering which screw sizes are supposed to go where :ror:
Will it be fine for most people, sure. Will it stand up to what many of the hardcore guys expect, I'd bet money that it won't. And while I can't point you to any Axial that I've ever owned that would out of the box, we have that huge caveat looming that we know that any thing we need to make it stand up will be made.
