Discharging batteries - does this sound right?
Naughty Dawg
Houston
I recently finished building a Wraith and chose 3S LiPo batteries to power it. I have a Racer's Edge 3400 may and a Venom 4000 may. I'm pretty new to RC and these are the first LiPo batteries that I have used. I have a Thunder Power 610C-AC/DC charger. I am trying to use the discharge function for the first time, working with the Venom battery. The battery had been on the discharge cycle for a little over 4 hours, and according to the readout on the charger, was only down to 11.64v. The default on the charger to bring a battery down to "storage voltage" is 3.52v/cell, at a rate of 0.25A
Questions:
I'm looking for 10.56v on the battery, right?
Should it take this long to discharge a battery?
I have the balancing cable plugged in - is this correct? (The directions for the charger are silent about this.)
Thanks in advance for the help. I've stopped the cycle for now, until someone can give me some guidance here.
The ideal recommended storage voltage for a Lipo is 50% which is 3.85v per cell. So, for your 3S packs that would be 11.55v (3.85x3)...10.56 is too low. You always want to balance them as well. If the cells are in good shape they should have no trouble holding that voltage for many months if need be. It's always a good idea to check them once in a while though, if they're gong to sit for a prolonged period of time.
You should be able to up the discharge rate on the 610 to 1 amp. That's still very low but it will do the job effectively. You can also adjust the "Time Out" setting if need be.
