mrklaw
Losi 4" shocks bolt right on as you'll see in various threads with pictures around here. You will have to bodge something though to use the Losi lower ball as it has an imperial size hole marginally smaller than the 3mm bolt.
enough material around it to drill it out a little wider?
Need to check for UK stock, or import and replace later - they seem relatively separate to get to from a replacement point of view - don't need to dismantle half the chassis to get at, so could wait until after I build.
