I mention this in another thread and would like some feedback or opinions on this topic. I'm not bashing, pointing fingers or saying one is worse then the other. This is just my opinion and what Facts I have been told and seen. Just want to see what you guys think. Now correct me if I'm total wrong..
The way alot of Droop set ups on RC Crawlers have the spring always pulling up on the Shock Piston to keep it Closed. So when Flexing the weight of the tire pulls on the shock. But the shock is always trying to pull the tire back up and keep closed. This would take away from Traction as the shock is trying to stay closed. Many 1:1 Crawlers run a Droop set up, but they are completely differernt then what most are running on RC Crawlers. They run Coil-Overs or AirShocks that were made for the weight of rig they are on. They also run Bump Stops to stop the Up Travel and limiting strap to stop down travel.
A good Link and Shock set up would do better. The only thing I can think of that Full Droop set ups help is to keep the COG lower and help on Side Hills. Also keep in mind that with a Droop set up that when driving you rig can change it's wheelbase in certian spots. So a limiting strap off the center of you axle to only allow a small amount of axle drop. This will fix the wheelbase changing issue, but still allow full Flex. I have watched a lot of these Droop Set ups and seen just about everyone have that issue when climbing over a rock the wheelbase changes b/c both axles are drooping to much at the same time.
Not saying that Everyones Droop set up is the same, but some I have seen would hurt more then help.
I think you would be better off Using some good Shocks and Making some Bump Stops either inside your Shocks or off your chassis to you axle to keep the axle from moving up. This way you can lower you rig as the tires won't be traveling up into the body. Now your shocks will always be pushing down for Traction and not trying to pull closed.
Here is a Picture that should explain what I just wrote. When most guys on here talk about Droop set up. The set up is not really like a True Droop Set up. Now correct me if I'm wrong. Buy doesn't the shock with the Droop set up always wants to stay closed. Now the normal shock always pushs down which would give better traction. Now like rigs like the Huslter with the Droop Set up. The Huslter and any other Tube Chassis will have a Higher COG then say the Stick Chassis, SW2, Pimp Cane or any other Light weight Aluminum Chassis. But since the shocks are set up with that droop set up. ( Now I said the Huslter just b/c it was the first production Tube Chassis to advertise the Droop set up and is the most well known chassis sold with the Droop set up) The Shocks help keeps the chassis pulled down and the axles pulled up. With a Tube chassis this set up might be better. But with any other chassis I think a Good Shock with a Spring rate for that rig with some sort of Bump Stop and something to limit down travel. Will be the best set up.
