My extended CC
List of upgrades:
Pro-line Hammers M3 w/memory foam
Axial beadlocks with custom outer rock rings, 2 -1/8 in. vent holes in each
3 3/4 oz.weight in front wheels and 2 oz in rear wheels
Aluminum knuckles front and rear
Cv axles front and rear
Aluminum wheel hexes
Duratrax Big Bore shocks with medium springs
Extra spacers on upper shock mounts
Aluminum steering links
Locked rear steer
All metal gears front and rear
Bearing kit
Aluminum links with bent lower links
Traxxes rod ends
Custom Stretched Frame
2 - DTX 1600mah 6 cell batteries
Heat sinks on front and rear
Aluminum Body mounts
Spektrum Dx3.0 Radio w/Sr3000 rx
Pro-line 72 Chevy truck body trimmed
Mamba Max on order
waiting for good motor upgrade "thumbsup"
Clocked front axle -it is now level
axial front steering links cut down
Axial offset rod ends on steering link clears axle housing for better steering, turns till knuckle hits axle housing.
Spektrum z590 servo
Metal servo arm
Moved links to outside of axle mounts
Mamba Max
Trimmed body for better clearance
