Digging up my graveyard build, I have stolen lots of parts off this in the mean time so here it is now.
Swapped the metal shafts out to a plastic shaft because I put the metal ones on a different micro.
RC4WD v2 trans and motor were taken out.
Proline ambush stock tires installed.
I had a random transmisson lying around and I thought I might as well use it. I think its out of a 1/24 EXC Temper but not totally sure.
To make this transmission bolt to the skid plate I have to file down this raised hole on the right side of the stock skid.
This picture shows the part filed down.
Whatever this came out of the motor plate looks like it was for a 030 motor and since I will be using the 050 barrage one I had to drill some extra holes. The holes that are slotted and tapered are old ones that won't work anymore.
The trans is slightly off center because the spur gear would of hit the servo wires going into the esc. Here's a quick shot.
Driveshaft angles are trash now :mrgreen:
It finally moved on its own power! It's slower than the stock setup but faster than the rc4wd trans v2 setup also. I think it was a good compromise. That v2 trans I felt it always wanted to bind up a lot so this is an improvement on that.
To fix that driveshaft angle I have some temper axles with high pinion diffs so that should fix it if I can get them mounted good.
All my other micro crawlers were sold so I got a good parts stash to dig into. Ill work on mounting those other axles and do an update if I can get anything done on it.
