I seem to keep popping the front center drive shaft apart the plastic spline in center falls out under shock compression
any help on this would be great thanks
Silicone fuel tubing is handy too, you can cut to desired size and keep the center spline always centered.
How does that work? It is squishy enough to be able to put the driveshaft on without taking the axle or engine off? ie compresses enough. Because even with the spring it has to go almost all the way together to get the front driveshaft on like about 4mm is all you get while pulling on the axle to the farthest point.
I mine actually just popped off again must have jinxed myself by posting. It was when I was doing stupid stuff back and forth really quick doing wheelies. I think I'm gonna get a better driveshaft at least for the front if I can find one that small size. Although maybe it is good that it pops so other stuff doesn't break.
I did the same. They fit perfectly.The Incision ones that fit the SCX 10.2 are a nice addition! I'm running front and rears on mine
