OK, here's progress over Christmas...
Starting with some more shots of the axles as I was taking them apart, inspecting and greasing them...
And now motor and servo installation. For the motor I used the stock pinions. The carbon fiber motor mount pictured is the Nordic Crawler Designs item. More about this in a minute... At this point it really strikes you how well these axles are put together, like a perfectly fitting jigsaw. I admire the brain that came up with this modular design of the covers.
Nice servo, at 7.4v it makes 630oz-in. :O
At this point, I would have proceeded with some shots of the electrics installation, unfortunately, due to heavy use over Christmas, by camera got mauled by various unskilled users both small and large (I'm looking at you wifey) and those shots seem to have been lost. So here's a token shot of the less visible shock mods, a 10mm fuel tubing spacer internally on the shaft, and a long rod end to help clear the servo and battery mounts.
Now what follows is basically the finished shots. In as much as anything is ever finished. It still needs foams and tire venting, as well as knuckle weights (waiting for Sniper and Turbos adapter) and lastly, mini T springs and cups. I'm going to try it out in the next few days, but so far I'm really, REALLY pleased. I have full clearance, full steering (ok, I'm rubbing the battery more than I'd like, but that's because its a big battery). The roof paint came out really wrong, in fact, its nothing like I envisioned it, however, I actually really like it, kind of a tribute to my home country and a show of supprt for the upcoming soccer world cup. Must thank Holmes and Chaotic for the epic logos, can never go wrong adorning an off road machine with gear and skull motifs. lol.
Despite the significant lowering from last time, it has retained a lot of articulation.
Front axle shots
Rear axle (sorry about the flying motor wires, they'll be reigned in in due course.
Receiver, sitting on an inverted and slightly bent Blue Monkey RC Bully electronics plate. Very handy, though I will be cutting a slither of metal off the side as it limits articulation ever so slightly more on one side than the other...I really like this solution for the RX so far...
A vanity shot
And the obligatory profile clearance shot...
As I put this rig together, I began to realise how everything is a compromise, and the need to drive the rig and match it to your style to make sure your compromises are giving you what you need and taking away something you don't.
Anyway, it is now fully RTR pending these final items.
Will be updating this as I tweak over the coming weeks.
