The giveaway winner will be chosen by a random number generator on September 1, 2017. To enter this giveaway you must be a star holding member here on RCC. If you need information about becoming a star holding member, click this link.
Post one time to enter.
C.I.'s Double Deuce Dual Stage for 2.6" MT Tires Foam Pair
Part # CWR-1202
Crawler Innovations was the first to combine closed cell and open cell foam into one package. The Double Deuce Foams have been around since the beginning and are made from the best compounds available. The Double Deuce Dual Stage Foam design is for all high-performance applications where grip and traction are essential. Available in a variety of compounds and sizes, the Double Deuce Foams are the perfect addition for your new tires.
Sold as a pair.
These dual stage inserts feature a Competition Cut, closed cell inner foam, with a Medium conventional or open cell density outer foam. The closed cell inner foam is super dense, water proof, is not temperature sensitive and is extremely durable. The conventional outer foam is not temperature sensitive, but it is not water proof.
The Monster Truck "Comp Cut" inner has six grooves machined into the area where the outer and inner meet. The machined grooves allow for the outer foam to collapse into them resulting in a much more responsive tire.
CWR-1202 was designed for use in the RC4WD B&H Monster Truck Racing tire, the JConcepts Firestorm MT tire, and the Pro-Line Destroyer Clod Buster size tire, but it will fit many other brands of tires as long as they are similiar in height and width.
Approximate size: 6.50" Height x 4.0" Width
#ci #doubledeucefoams #crawlerinnovations #rccrawler
Installed in a JConcepts Firestorm:
On the C.I. Rat Rod Mega Truck:
Available @
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
Thank you for entering and good luck"thumbsup"
Part # CWR-1202
Sold as a pair.
Available @
