Started this thread looking for shock advise, so why make it a build thread as well.
Bought a PS wraith. Way to high, way too ugly.
Cut the top off, flipped the rear shock mount, moved the front shocks back.
Stock motor is garbage, threw a 21t Titan 550 in, much better. Also dropped in a Savox 1230SG with a castle BEC and built some steering links out of piano wire.
Rock hard RTR tires couldn't keep up, picked up some RBIIs and Pitbull Dos Piezas foams. Made lower links from Traxxas push rods, swapped all the rod ends for steel.
Foams didn't fill the tire properly, and wheel screws were starting to strip. Time for CI DD foams and some Hitmans. Beautiful combo. Also threw on some Slash Powerstrokes and made some brackets to raise the rear upper mount a bit.
Plastic bumper was flexy, so I copied it out of steel. Takes a beating and looks even better now that the paint is scratched.
Beat on it like that for a while, interior broke apart and came out the windshield on a hard landing. Trying to track down an Appache insert, but they seem to be nonexistent. Installed some MIPs, lasted 5 minutes or so and bent the lower trans gear.
Ordered a bunch of RRP trans parts and put everything back together, all good now. Also threw in some Axial universals and Vanquish scale chubs and knuckles. Receiver died, picked up the FlySky version for $8.
Got bored of the 550 brushed motor, and picked up a brushless 4550kv system for cheap. Geared at 87/18 it was pulling wheelys and going 25mph. Dropped in some lower gears, 64/11 32p, tops out around 20mph and still pulls wheelys :mrgreen:
Spent a lot of time crawling and a lot of time at the dirt jump park. Came down off a double hard and bent a rear axle shaft. New shafts, new bearings, good to go again. Broke the roof bars a few times, lots of super glue and electrical tape and shes holding up fine.
Then I started this thread. Dropped the rear shock oil to 20wt, blew around the back lot for 3 laps, and the front diff came apart.
So now she sits, waiting for a front spool to show up. The slop in the lockers never bothered me, and the rear still looks good. The stock locker isn't up to the task in the front, so some from lockuprc or hot racing will be out to the test.
The body is hammered. Cracked, bent, broken and broken some more. Looking for something to replace it, but not feeling inspired.
Current condition. Desperately needing a diff before this long weekend.
Looking for a little shock tuning help. Above 15mph or so, the back end gets a little light, bounces on big hits instead of taking it in. The front handles things perfectly.
Basic set up:
PS Wraith, cut to a fastback
Battery, receiver and BEC up front, ESC just behind the tranny
4550kv brushless geared 11/64 on 3200 3s hardpacks
Slash Powerstrokes F/R, 80mm front, 100mm rear.
Rear upper mounts raised 10mm, bottoms of all shocks mounted outboard of brackets
1 step softer on all 8 springs, from proline tuning kit
30wt oil all around
RRP tranny gears and MIPs
Pitbull RBIIs with CI Double Deuces Medium all around, on RC4WD hitmans, tires vented at 4 spots
The rear truss hits the floor just before full compression, but I don't think that is the problem. I can go one step softer on the secondary spring. I'm new to the go fast stuff, no previous experience in short course or anything. The rear end in significantly lighter than the front.
So what's the way to go? Softer secondary spring, lighter oil, more vents, softer foams, move some weight around? What says the power of the RCC?
Proline spring tuning chart, currently at Blue/Green front and rear.
http://prolineracing.com/images/howtos/setupsheets/PowerStrokeSpringRate.pdf
Basic set up:
30wt oil all around
