Good, better, best shocks for CFX/CMX?
gsgraber92
Anderson, SC
I am currently running the stock shocks and my rig is a bit heavy on the front end and I have very little travel. I was thinking about changing the hoops or shocks. Either going to a 80mm shock (but not sure what to go with) or design my own hoop with more mounting positions to raise the front end a little bit. I have the Lexan FJ40 with roof rack and planning on a tire carrier for the rear at some point. Anyone have any thoughts or recommendations?
I knew King’s were probably a good option. I’m not a huge fan of the blue anodizing. If they were silver/black/dark gray. Is there a easy way to remove anodizing?
The new proline shocks look very good and either 70mm or 90mm
I redesigned my CMS to squeeze a few more millimeters of up travel (it’s on the printer). So the pumpkin will have more room to travel now. I am also designing a new shock hoop to give me some mounting options. So if I want to do a droop setup with a longer (80-90mm) shock I can.
Im looking into a wrangler build on the CMX chassis but looking to upgrade the shocks. Was thinking 70 or 80mm pitbulls.
Im going with a scale build, Will the chassis run OK with 80mm or best to stick with 70's?
I have the 80mm ones, TC80, sold under MST brand, replacing the 70mm stock shocks.
In my opinion they act smoother, rises the clearance to ground a bit in CFX.
