GT3B Hack Question and Answer Thread
Is there a way to map CH3 button to turn 4WS on and off? And would it be possible to have the CH3 button be a mommentary button for it? What I mean is can it be setup where it's just normally 2WS steering but if I press the button down then it's 4WS mix so long as I hold the button down?
No...BUT you can do this with a switch
Seriously?
So your asking how to reverse channel 2 correct? If so you just scroll to REV, press enter, scroll to 2, press enter, scroll to REV, press back/end afew times.
Is that for dual ESC's?
For some reason the trigger is backwards. Pull in, reverse, push out, forward.
And yes Seriously.... I haven't had a whole hell a lot of time with it and the online manual is about as worthless as tits on a chicken!
EDIT: Now I know why you said "seriously"....It was easy. I reversed ch 2 and 3. Got it thanks.... I'm an idiot.
.[/QUOTE]
Well if you want to get technical tits are breasts and that's probably the most desirable part of the chicken so... :ror:
On the TX? How would I do that? thanks.
Long click EPA
Scroll to 4, enter
Scroll to CH3, Long ENTER
Long Click REV
Scroll to 3, enter
Scroll to NOL, enter
Scroll to 100, Long enter,
press end afew times.
Plug front servo into ch 1 and rear servo into ch 3.
Ch 3 switch will go from rear steer only, even mix, to front steer only
EDIT. I forgot, If you want momentary
Long click EPA
Scroll to 4, enter
Long Click REV
Scroll to 3, enter
Scroll to MOM, Long enter
Well if you want to get technical tits are breasts and that's probably the most desirable part of the chicken so... :ror:[/QUOTE]
Good rebuttal.... I said that to my sister in-law.... She had this blank stare for a minute and says..... Well aren't they born with soft beaks?.... It killed me! :lmao:
I have one coming when ready, I may consider skin also...just need to see idea of skins ...Btw is it worth idea of a clear skin for screen? As in screen protector.
X2 I would like to see what the skins will actually cover. are they replacements for the factory decals? or do they cover more?
as far as screen protectors I dont have my GT3B handy but I'm sure some cellphone and tablet screen protectors are close enough to work and they are very cheap, also can be easily trimmed to fit better.
I use some screen protectors left over from my palm pilot 7X days (prob not still available as that was late 1990's :shock:) for my misc devices
i've put a screen protector from i think best buy on mine, lot less worry. also interested in what the skins would cover, i'm working with a local vinyl guy on sticker replacement and screen surround on mine.
Try flashing abunch of 0's (don't load any firmware) Then flash 0.4.1 again. See if that fix's it. Your issues are strange.
You may also want to make sure that the the trigger and st wheel are plugged into the right spot.
that is the worst part, I am pretty sure I never actually flashed anything into the radio, remember i was the guy with a problem board that never communicated with the radio, yet somehow all my channel got reversed, and ch1 is now th and ch 2 is st?? also the radio can control a given tx in any of the model memories I had programmed for the other tx's I have, additionally I forgot to mention that forward is limited to about 10-15 percent throttle and is stuttering , I have rebounded the esc to the radio and EPA and setting and trim at 0, so I want to reset the stock radio with the stock firmware , please help.:cry:
The skins will be like the other templates I do. From what I can see as I do not have one in my hands but from the images I have...
They will be done similar to our other templates. They will change the look of your radio by accenting not completly wrapping the whole radio.
The base will be done, sides, front, the top may have a few pieces.
Take a look at some of our other radio skins like the Traxxas 2.4, 3e(we are only ones who make them) 3s, 4pk, 3r.
"thumbsup"
I'm confused...just plug it in, open up stvp, flash the zero's. Exit out of it all, un plug, then repeat but open 0.4.1 then flash
If you never flashed it then its stock firmware, if its not stock firmware then you flashed it. If you flashed it once you should be able to flash it again
For the skins, I'd be possibly interested, but really $45 is a little higher than I would want to spend. That's not to say your skins aren't worth every penny, because they are definitely worth the money, it's that I'm too cheap to pay more for stickers for the thing than the radio cost me total.
To clarify though, the $45 would allow us to get a completely custom skin for this radio? Or is it just a choice of a few basic designs? If it's custom, it's definitely worth it, if it's just a choice from a few designs, I'm out.
