GT3B Hack Question and Answer Thread
Likely dumping them with the new ones coming out........:roll:
Doubt it, i was talking with flysky about ordering the new radios...they won't start production till the end of the month and they told me, i was "ordering" 100 units, that i most likely won't have them in my hands till around may because production lead times and they'd ship frieght so it take 4+ weeks to get them.
Sadly i don't have 4-4.5k to invest into radios i won't have till may. My price was 37 usd before ship. So they'll probably retail 50ish here in the states.
The GT4 we won't have till like Christmas time as its still conceptual and being designed
Hey guys, getting ready to order in some Aluminum Steering wheels for the gt3b..and will fit on other radios, unsure which ones though at the moment.
Anyways, i'll have a pre-order type thing up on my website shortly. Two wheels be be offered, an 8 spoke and a 18 spoke. (Stock wheel is a 5 spoke)...they'll come with 2 foam grips.
Just ordered an 8 spoke one :)
Pete.
Error : Cannot communicate with the device ! Check the SWIM cable connection and check all the needed pin connections on the SWIM connector.
installed hack kit , followed instructions ; now what?
Did you follow instructions to the dot?
its very picky about the order you do things, and when its a swim error, its usually because there is a bad connection or the steps weren't followed correctly
swim error was fixed by re-soldering connections.
now i am having trouble setting up.
Finally got my XR10 built and running so I can test the GT3B. LOVE it! I'm running a 3 ch punk dig switch and it works perfect, I have it set where the ch 3 trim button switches from front dig/ 4wd/ rear dig and holds the setting. And I have the D/R switch set to momentary front dig/4wd/rear dig, that way I have momentary and hold for my dig. Thanks again losikid for offering the kit and support, and thanks to the genius that wrote the program!
what are the steps to set up like this?
Long click REV
scroll to 3, press enter
scroll to CH3, press enter
scrol to NOL, press enter
scroll to 100, Long enter
press back/end afew times
Long click REV
scroll to d
scroll to CH3
scroll to MOM
Log click enter, and press back/end afew times.
Your done, plug your punk dig into ch3 on the rx
Wheels?? Oh wow ill have to check that out and just got radio last Monday...thank you.
But 50 some pages...I don't wanna read all to find answer...but I wanna lipo mod radio and does it really matter between the 2s or 3s as mah is what's needed for long battery life...anything to say on this subject?
No, 2s and 3s both work if vr mod has been done. BUT, the lowest voltage possible is 6.5 volts, so you'll be losing some ma's with the 2s.
Alright guys, i have slightly bad news about the wheels...the adapters include that said they work with the gt3b radio, clearly are WAY to big. However, for those whom have ordered or will order i'll be including a small piece of .015" shim (just styrene) which by placing on the flat will make the adapter work..
Also, only 1 set of foam will come with the wheels from now on (pre-orderes will still get two). and offering the other foam for individual sell. The foams actually feel quite nice compared to the stock rubber.
I'll be emailing everyone who have pre-ordered and offer a refund if the shiming idea is unacceptable.
I'm currently trying to contact someone worthy at the factory to see about getting the right adapters made. The Chenglish language really needs to be improved. If i can't figure out anything for the adapter i'll probably discontinue the wheels, i don't like selling products that don't fit good. Funny thing is they include 2 identical adapters, so maybe this is why they don't fit
I ordered this steering wheel when I bought my GT3B:
The foam is comfortable, and the adapters that come with this one work fine for the GT3B too. That was one of the first things I wanted to change with this radio since the stock wheel is so cheesy and the rubber isn't that great.
Yea, it looks like it's the same factory. Are the two upper adapters the same size in yours?
Here's the 8 spoke wheel, 18 spoke is the same style just tigheter spaced
I was going to go with some color and cooler styles, but figured i'd stick with plain ol aluminum first and these were the only two options, also abit cheaper. (I ordered directly from the manufacture (i think))
Can someone please post up pictures of the 6 channel receiver for the flysky GT3B please. I want to buy a set up so bad but wanna make sure !"thumbsup" Your help is greatly appreciated!
Hey losikid kid when i turn my radio on, after my model name there is a voltage. Is that the cutoff or what? If so what should it be set at? Thanks
