63comet
Rig looks great, nice job"thumbsup"
Is there a reason you didn't just unplug the antenna?
Looking forward to your updates at that comp. Are you planning to do the free 1.9 event?
After the last couple times crawling I realized I do still want a little more weight up front. I was going to put a couple ounces of lead in the wheels but instead I am going to switch to the VP knuckle weights which will allow me to run a little heavier without any extra wheel weight. Plus it will give me a little more bling.
Running my SSZ's with 475 hubs, this will allow me to go up to 6.17oz of weight per side, which is a little under 2oz heavier per side. I am happy with that as a starting point. I will try that and see if I want add any additional weight.
Whatcha doing with those .300 rings, or is the bolt pattern the same?
