help! comp crawler wont crawl
ltuck808
gresham
hey there i have a Team Losi Comp Crawler. my crawler has a traxxas 12t titan motor and a traxxas 3000mah 7 cell hump pack and a new danamite lipo tazer 10t esc that i baught (10/12/11) and the 2.4 axial radio, it also has 2.2 Team Losi rock claw tires, ( my dog got a hold of the Pro Line Super Swamper tires i had for it) but. , it has a dig transmission in it (not hooked up.) It also has the worm gear drive axles. So heres my problem. Whenever I hot a obstical it just stops and motor wines. Idk if its the battery not giving enough juice or what? I'm wondering if there are typical problems that someone could help me with. Hopfully I can just buy a lipo and run it. I also just bought a Hong nor 3 channel remote 2.4ghz with a Hong not 2.4 hnr-3 receiver or whatever so I can hopefully run DIG. I already have the dig tranny hooked up but still using the 2 channel junk. I need to know if those parts I just bought are correct and will work for dig and also if I need a servo or whatever they're called to lock the dig tranny in and out. I'm new at this and don't know all the fancy terms so please try to keep it English haha thanks please help!
Logan..
you need to check the losi comp crawler threads,I`m guessing your axles need some attention as they require constant maintenance
I believe you have a slipper clutch on that rig. It sounds like you need to tighten the nut that put pressure on the clutch.
