Creepcreep
I know this could easily go in any other number of threads, although this see,s to be particular to my set up as I've read all the threads I can find and they conflict based n my equipment, hoping someone can lend some insight!
My set up: Sidewinder v3, Tacon 1370kv 2 pole, 3s 30c, spektrum sr301, spektrum dx2e, Savox sw0251mg(I think, it's the big one) glitch buster installed. Ax10 Ridgecrest.
So here is the issue: in my basement crawling around on my track by myself it's fine, no glitching, good torque to the motor, perfect reception. Then I go out with my buddies who all run stock axial RX/tx, and the motor jumps in and out constantly. Doesn't matter if I'm close by my tx or not, the truck jumps all the time. There comes certain points where I have basically no throttle control at all, it just sits there while I fully squeeze the throttle and kicks in and out. I also notice a ton of lag in power....almost like it needs to wind up like a turbo.
Possible solution number one: I've read Savox drains receivers. Should I replace it with a different servo, and if so, what?
Possible solution number two: BEC, this makes the most sense to me, and I really don't want to pull my servo, so could this be the cure? If so, what sort of ratings should I look for in a BEC running one standard, high torque/high draw servo?
Possible solution number three: Spektrum plus Friends nearby equals PROBLEMS. A bunch of comp guys I know said that spektrum sucks when you're around other non spektrum radios. If this was the case, why doesn't it glitch in any and all of my other trucks when I'm around other cars(most of those are racers, not crawlers)? And it seems very strange that spektrum and only spektrum is the RX/tx combo that is glitchy.
Any input or advice? The cheapest and easiest answer is a BEC, so I'll probably go grab one of those today. Just curious if I really need to go all in with a castle BEC or if I can opt for something smaller?
Thanks a ton in advance, this problem is literally shutting down my driving so if you can help, I'll owe you one!!!
Creepin
Creepin
