Buy A VP case and that will be the last time you ever need to buy one. "thumbsup"I just received a trans case where the bearing seat on the extended side wasn't milled properly. The bearing would only seat about 2mm. Not pleased but will see how the dealer handles the return.
Any other options for a aluminum trans case? I see a yeah racing one on amazon but not sure of their quality.
For the trans case I figured there was enough metal to negate the soft aluminum. Would have worked fine it it was machiened correctly. I'm fully aware things happen and honestly, I would be fine with a replacement rather than a refund.
VP makes Wonderful products but they are not on amazon and unless I'm making a big order it doesn't make sense to order from RPP. I have cheap al case for the scx I got an amazon and I've had no issues.
The Hot Racing locker is a good piece, even if the shaft fitment is a little sloppy. Used and abused a pair of them, and they kept on going. Recently sold them and went to the GripFab locker. Much tighter fitment. Probably means I'll be twisting axle shafts in two now. :lmao:
I went looking for a extended VP case and I didn't find any. Not sure they make them. I saw that supershafty was using the HR case so I thought I was safe. Sucks that it wasn't milled correctly but things happen. I really don't see blowing up a trans case in the future but I'd rather a aluminum one for less deflection under load.
Could I get a VP one? If they made a wraith specific one I would consider it. Will the $25 GPM one I just got work just fine? Hopefully. I have limited funds and sometimes I can't spring for every top dollar part. Steering knuckles and hubs, VP all the way (even with them I got a set with questionable threading on one of the hubs) Rear lockouts? You will probably be fine with anyone but integy.
