I finally had a chance to race my Mudboss this weekend. I started with something close to the Mudboss suggested setup for a loose track. I'm not a fan of that setup at all. In practice I could not get my car to turn unless I slowed down a lot for the turn and I was off the throttle or at least only using partial throttle. Because of this I started getting hard on the brakes into the turn to get the rear end to slide out. I spun out a lot learning this. After some tweaks the car seemed better, but I still wasn't happy with it.
In the first heat I started 9th out of 10 and finished 4th. Not bad considering it was my first time out with the car and I wasn't happy with the way it was handling.
I made some more tweaks before the second heat. The car seemed to get worse. The severe push had returned so I resorted to braking hard again. I spun out a lot trying to slide the car because it simply wouldn't turn any other way. I finished 4th out of 4.
With those results I didn't make the A Main. I made some more changes before the B main. I am not a setup guy. I typically setup a car and learn to drive it. I told myself to just drive the car that way it had to be driven in the main. I decided I was going to brake before the turn, get slow for the turn, and drive out hard. I also decided I was going to brake on the straight so I didn't spin out in the turn. I pushed hard, tried to stay focused (difficult for me), and tried to stay consistent. I started in 3rd and about 10 laps or so into the race I took the lead and never looked back. I was happy with a B Main win for my first outing.
I got bumped up to the A Main where I started 6th out of 7th and that's where I finished. My new battery didn't seem to have any pep.
I need to try to get the car to turn. Before the main I put a larger spring spacer on the left rear shock and the next smaller sizes on the right rear shock. I was thinking this would lean the car forward and put more weight on the front wheels while also putting more weight on the right rear tire. I think it helped a little, but not as much as I wanted. What suggestions do you guys have for getting the car to turn better? Thanks.
