So I have made some progress on the rebuild..
Stripped down the axles cleaned up the gears ready for milling.
Here is a standard axial lightweight gear( 3 in each transmission)
Now I did the front and rear gears differently
This is the front gears leaving 4 webs
The rear gears have had 2 webs left
And this gear was an extra that Allan's old man knocked out on the lathe, it already had the holes opened to 1/8
Both front and rear spools were done leaving 4 webs
Next was a gearbox clean out, new bearings in the trans, all new knuckle bearings.
Front gearbox before closing up(rear looks similar gears are just milled differently)
I also changed back to the vp trans centre section as I found a crack in the plastic one and didn't have a spare.
Front axle complete ready for servo, I have swapped out my sds 300hds for some dlux modded axial unis as the hds are in need of new bushes and I can't get hold of them at this point in time.
The rear axle was built with new bearings also.
That's all for now, I have a few other tricks up my sleeve and am also waiting on a couple more parts to show up, but I hope to have it running in a week or so.
Josh
