Just bought yeti xl rtr
47yok
usa
Hi everyone.
Just bought it yesterday. Found this forum last night.
Already have read about the rear end bounce and what springs and oil to try. Awesome info.
I don't have much knowledge of rc stuff but I'm learning.
Things I'm looking to do.
Lighting, so I can run it at night.
Springs and oil.
Read up on getting better steering. Thing turns like an old mack truck. That will take some time though. Don't know what a BEC is or how to wire it.
Much learning to do.
I'm running it with venom 5k 20c lipos.
I'm impressed with it. Really good Power and run time is good to.
Time to go play. Batts charged up.
Have fun everyone.
Just got back home. Ran 1 set of batts thru it. Took it up on the power line trail behind my house.
It run very good over moderate bumps.
But hit something to big and the rear passes the front in the air. Fun to see but not good for it.
Definitely needs more ground clearance in the front to.
I can see it doing excellent on a dirt track with jumps though. I can say it's a tough little guy. End over end several times and nothing broken. Next weekend I think I'll try the dirt track at my lhs.
Tomorrow I think I'm gonna see if my lhs has white and green springs. Get some 35 wt shock oil to.
Let the mods begin.
Yup read that in the Manuel last night.
But the lhs sold me what I got.
So this is why I have them.
Nice catch Yota !! I skimmed right ovha that !"thumbsup"
@ 47 "thumbsup" welcome these guys are GREAT they helped me when I was a forum peaker reading their mods and how~to's
so I decided to pay~it~forward by pushing a bunch of mods that aren't available online...DIY (FREE) or order from BHB
"thumbsup"
BHB High Clearance Mod almost 4":twisted:
https://youtu.be/St4tw_9VUec
check out my RRC profile for picture reference and my aftermarket parts & mods
I don't do hobby store lipos anymore you probably paid way to much for them and if the guy behind the counter knew any better he would have never sold thm to you, or he sold them to you because they are making killer profit on them.
Until you get a better understanding of lipos just run those till they are dead or you see signs of major puffing, then when you have a better understanding of how to read the specs of lipos and how to take care of them get some better lipos, plus Graphene lipos have recently hit the market and so far they are looking pretty good.
I am personally against hobby stores anymore, I order online only now.
Here is a killer lipo guide
A Guide to Understanding LiPo Batteries - Roger's Hobby Center - Radio Control (R/C or RC) Cars, Boats, Airplanes, Puzzles, Plastic Models, & Trains - Saginaw, MI
Here is some great lipos from SPC
SPC LiPo Battery Power, Lithium Polymer Battery Packs
Their are cheaper lipos such as turnigy from hobbyking that deliver great performance, but you are typically dealing with china with possible longer shipping times and maybe poor customer service, but many guys swear by the turnigy lipos
When shopping for new batts also pay attention to the size dimensions vs the size dimensions of the battery box on your rc
Thanks for the lipo link.
Already had found spc and bookmarked it.
I try to use small businesses when I can. I look and see what I'm buying. I'm seeing on here though ebay is a good source.
Just ordered from dhawk. Got the drag link and bell crank
Assembly on the way. I hope the install goes easy. From I've read on here should be no problems.
Now to search for a better servo.
Definitely stick to Jumpit's advice and read up on Lipo batteries with that guide and many others on line. Always balance charge and balance storage charge them. Don't hold full throttle for too long with those Venoms. They are only 100amp batteries. And find a safe fireproof place to store them when your not using them. I may sound paranoid but read up and play safe and you will have no issues.
That article on lipo batts was excellent.
That should be included with the rc truck.
Guess I'm going to replace the adapters
On those venom batts. Thanks all.
Could use a little help with parts.
Lost 2 rear shock upper bushings
Last night. Couldn't find them anywhere.
Part number ax31031. Been trying to locate
But no size listed in manuel. Anybody have a number
For a substitute?
For a substitute?
I used thick straw from a refill water bottle with a washer...works flawlessly.
I'm sure if you looked:shock: around you would find something useable..
OK.
Here's what did last night when I
Lost those bushings. I moved the rear
Shocks to rear hole. Just to try it.
Cause when a shock is angled it reduces
Spring pressure. When straight you should
Have actual spring pressure. I charged up a set
Of batts tonight and ran it. For my type of running
And some small jumps about 2 to 4 ft long and 30 in
High. It works much better. Torque steer is calmed down
Also. The front springs need to be a little stiffer as I have them cranked 3/4 of the way down.
Much better for my type of running.
Next is the steering upgrade as posted on here.
A question I have is what have you fellows
Mounted the bec?
This really is fun. Testing, research, then modify.
After the steering project it will be a rear
Sway bar. The torsion bar style. That should
Really help to plant the rear end.
Thanks to everyone for the info in this forum.
A question I have is what have you fellows Mounted the bec?.
I have the small blue castle bec, I filled it with silicone to waterproof it then mounted it to the side of the tub just behind the receiver box with double sided tape. Make sure you get it low enough to clear the transmission case. Seems to work ok there for me.
I posted a thread a couple pages back called ok it's done. One of the photos shows the blue corner of the bec under the transmission case.
Thanks sparwood. Looks like good spot.
The cc bec is what I got. Also ordered the
Programmer to set end points.
Most of the parts came yesterday.
Waiting for the dhawk steering.
New rear spring in. These hr springs.
The red is 3.3 lb I think.
About double what the factory had in.
Here's the front. Increase of about 1.5 lb.
It sits better anyway.
Really jumps better.
Definitely an improvement.
I may try putting the hitec servo in today.
My concern is programming the cc bec.
Then getting the end points set.
I haven't done this stuff before.
The first time on the CC software is daunting but 2nd time you can do it with your eyes closed. Loads of options but very well layed out and easy to navigate.
Setting end points is no big depending on your radio. RTR radio?
As always if you get stuck there are a lot of helpful guys here and throughout the site to help.
Yup the radio is the rtr tactic.
I was hoping to be able to do
It thru the cc link. The outline
In the book is confusing.
download cc program
hook up cable
plug in cc programmer chip or field card
look for green lights on the computer screen
plug the chip into the end of the ESC cable that attaches to the Rx
ready to play
same goes for adjusting the BEC "thumbsup"
download cc program
hook up cable
ready to play
The guy I had on the phone told me the the red wire at the rx has to be removed from the plug. Otherwise fries your rx. This is the plug on channel 2. Throttle servo.
If you want to program esc later you will need to put wire back in.
BECAUSE the rx in this can only handle 6 volts max.
Otherwise Fried. I wanted to set it at 7.4 but then he told me nope.
I can do the 7.4 volt, but I need a y connector for the bec wires. Then the bec connector that goes to rx Has to have red wire removed from plug.
He was adamant about this.
Hooked up and downloaded the bec program and set it for 5.9 volts. Gonna order the y connection tomorrow.
As he sent me the link for it.
