Pro level chassis kit at an Entry level price - That is the Krazed Goal!
Our un-Stuck line is designed for the 2.2S class of competitive rock crawling and has been showing great interest from new drivers as well as veterans of crawling.
Based around on the popular Losi Night Crawler/LCC axles and Night Crawler transmission.
We kept the sleek simplicity of the un-Stuck and worked in the ability to tune your Losi geometry and suspension.
Capable of mounting the transmission with motor forward or rearward by simply flipping the skid direction around and swapping chassis side plates.
Good for changing chassis weight bias.
CHASSIS:
2mm 3K Twill Weave Carbon Fiber
CNC Cut
SKID PLATE:
CNC Machined Delrin
Pocketed to relieve material for weight
Encapsulated lower link system
Overlapping side edging to help protect carbon fiber
Reversible mounting to change motor weight bias
HARDWARE:
(4) Axial 55mm Black aluminum cross braces
3mm Stainless steel fasteners
DRIVETRAIN:
Direct Bolt in for Losi NightCrawler (not included)
SHOCKS: (not included)
We recommend 3.5'' shocks for the un-Stuck line.Wether they be Axial SCX/Icons or Traxxas 2662 big bores that becomes drivers choice.
Due to the Losi axles having a narrower mounting location compared to Axial we found SCX shocks to fit better. Traxxas caps may bind against the chassis due to their size unless you choose to run them upside sown.
FRONT/REAR AXLE PLATES: (not included)
This was a spot we thought to help save drivers money and give them choices. Losi axles have upper link mounts and their own servo plate.
Drivers can choose to use their existing mount locations or we do offer front and rear plates separately.
Our Rear plate is a direct bolt on to the top of the existing plastic mount.
Our front plate allows for you to mount the battery and servo directly over the top of the axle.
**Note though, we have sold this plate for stock width Losi axles and have heard of steering clearance problems. This plate is really intended for front axles with some sort of XR conversion done to them.**
PRICE:
$60.00 /plus shipping
sku - unlos0089
Available through the store
Catalog
International shipping is available at check out
As always - Thank you for looking and all the support. Any questions feel free to PM me or post them up. "thumbsup"
