Lipos in a React
CrawlHer
Sedro Woolley
ok guys i did some research but i didmt really find what i was looking for. i have a nomadio react setup for lipos and iam looking for a place to buy some lipos that will fit in the radio. if you guys can point me in the right direction taht would be radtastic"thumbsup""thumbsup""thumbsup"
thanks in advance
CrawlHer
Measure how much room you have, then go shopping. Most reputable battery retailers list measurements. "thumbsup"
i did measure but i dont want to buy one and have it not fit like i did once because i relied on the specs on a website. iam looking for one that people already have tried and i know to fit. i dont like the trial and error thing when spending this much on batteries
do you happen to remember where you purchased it from War Pig?
my bec is setup between the lipo and radio. plug battery into bec and bec is always plugged into the radio. bec is set to 6v
Gilbert the 2200 2s flightmax packs fit but the wires are a bit big. I can get you a link when i get home. I cut them off and replace with 20 ga. Yeah more work but whatever. J.B was using some 2500 2s packs with small wires and JST plug installed but cant remember the brand. Post up on Warcrc or shoot him a PM.
i texted JB last night and he is using some packs from fusion-pack.com but there website seems to be down. those are the ones i wanted to use. do you happen to know what batteries diamond dave uses in his react?
if you can get me a link that would be great.
Thanks
CrawlHer
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=14972
Big wire but will fit with slight trimming or rewrapping and shrinking.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=16778
Will fit as is smaller wire 14 ga a bit big if you run a JST on you bec.
Both in stock in the USA wharehouse so you should get them in 1-2 days. Whatever you run make sure you unplug the bec from the battery or it will drain it down over time and possibly damage your lipo.
Thanks moes i think iam gonna get the one with smaller wire. iam gonna get 2 of them. on the bec note i unplug it inbetween coarses, comps and well pretty much anytime iam not using it. thanks for all the info guys"thumbsup"
CrawlHer
CrawlHer
I said I'd do that too, until one day I didn't and wiped out a pack. Now there is a big sticker across the top of mine that says "BATTERY!!!!".
