So then I have a couple suggestions to put this ESC in much closer contention with other available choices. Update your website to contain all of this "corrected" info, add a programmable auxiliary wire to switch between drive modes on the fly, and drop the price $60. I still see the Mamba X and MMX being a much better choice because if prices were the same, Castle gives you the aux wire. If Castle didn't have the aux wire it'd still be $60 cheaper. Castle has two clear advantages with all other considerations being equal. Castle also has a higher voltage switch mode BEC handling 8v, or did Tekin update this too?
I'm still not fully understanding how all of the original specifications and limits were posted then updated to be very close to Castle ESC specs (your 4s limit is still a bit low) but I'll take your word for it. Were upgrades made to the ESC or additional testing performed to raise the voltage capabilities and motor limits?
The website is updated and has been for a few months now. The BEC has been a programmable high voltage 8amp since launch and was originally developed on the RX8 platform and implemented on the GEN2 and now improved on the GEN3/RX4.
The specs we chose originally were to separate it from the RX8 as we don't intend this controller to be used in 1/8 and 4WD short course offroad racing applications. It was developed with rock racing and trailing in mind and I didn't see any need to have 5S and 6S ratings since I never see anyone run setups at those voltages. After a few people complained about the input voltage specs, we decided to just let it run up to 6S since it's basically an RX8 in spec anyways. The most common are 2S and 3S with some 4S thrown in here and there. In my testing, I actually prefered the 4S in the YETI/Bomber/EXO types because it was incredibly smooth, low amperage, low temperature and really good mAh mileage. The voltage capability was always there. We did lots of hard bench testing and they handled incredible amounts of current without fault.
The auxiliary wire is an awesome feature, you can bet that it's been on my list for some time now. Now if those dang software engineers could make it work, I'd be ecstatic. It's just software so it should be easy
Price I can't really comment on since that is not my area, but I would expect you'll see them come down a bit.
