Maxxmasher's Double cab Hilux build!
I made it to the hobby shop and picked up a set of Micro T shocks. I wish they sold these in pairs, so I could get two sets of rears. It's alright though, I really only need the to replace the rears. Due to the angle of the front shocks, the front sits low enough.
Comparing the lengths of the micro-T's rear shocks and the crawler's stockers.
Took apart the stockers to swap out the caps.
Mounted up and ready to go. I took off a few of the coils to allow a bit of droop.
I also picked up some magnets to better attatch the hood. It was fine at first, but after a few roll-overs, it kept popping off.
I glued them to some dense foam to raise them up to hood level....
and attatched a couple of metal strips to the underside of the hood.
While picking the magnets up, I spotted these.....
which make for some good tow mounts.
I also got into taking apart the wheels to add a bit of wieght and to star-cut the foams.....
I added a few wraps of solder to the rim and did a little work with a razor....
And then I decided to paint the centers with a little chrome silver.
For the fronts, I'll use these for more weight and skip the foams all together. These will suffice until I get some proper beadlocks.
I also grabbed this guy.....
Gotta have someone riding shotgun! (I threw the rears on one side to see how they look. I'll get to the front wheels a little later on...)
I decided to add a final touch to the front of my micro by adding a fairlead and a winch cable. The clasps I picked up were the perfet size.
My home-made fairlead - a piece of plastruct and a little silver paint.
My "cable" and winch hook
The completed project - added some hook mounts, too.
I finally got around to getting some lipo's to run in my micro scalers. My Bro-in-law was coming for the long Thanksgiving weekend and I knew with us running both of my micros, we'd need a little increase in run-times. I didn't keep track, but these things seem to last forever! I ended up getting two Thunder power 2S 325 Mah 45C lipos. They're a little bigger than the stockers, but they fit fine in the scalers. These would be too big to use with the stock crawler without modification. I still have useable low-speed control thanks to the settings on my Spektrum radio, but the tires almost balloon when I smack the throttle! I do have to be careful though, as like many have found, the stock motor will heat up a bit. I keep the temp gun handy now, and give the trucks a break when the can is a bit too warm....
Size comparison next to the stock pack.
Tight fit, but it works!
Plenty of packs for almost non-stop running!
I've been running the truck pretty hard and I ended up breaking the frame. I had already fixed it twice, so this time I decided to get some brass and craft one up myself. I considered trying my hand at using silver solder, but I've never done that before, so I used some small screws to make everything.
Broken model frame
Replacement brass next to the old plastic
I also picked up this Mini-T screw set when the guy at the shop offered it up for half price.
Had to pretty much tear apart the truck
Lots of screws, but it's nice and solid
I also gave it all a couple of coats of flat black
I decided to change the position of the front shocks, so I also had to make some new front links with a slight bend because they were rubbing on the shock bodies. Just using the white ball-ends for now. Gotta get some black ones to match the others.
A little tape to get the bed to line up while I mark the holes to secure the bed.
Everything came out pretty good. Rock-solid now!
I also got some new wheels and tires recently, as I mentioned in another thread....
