METALHEAD
Okay, new build eh?! I’ve wanted to make this build for a long time. I’ve had the body lying around for about a year and I just needed a nudge to get moving on it. That having been said, the nudge was Unimoger’s All NW Scale Meet in Helena, Montana this coming May. I don’t see any reason why I won’t have this bad boy done by then. So far, I’m happy with the way it’s coming together. Any pointers, tips, suggestions, critiques, creative criticism, insults (HEY, up yours too, buddy) and all that would be greatly appreciated, so if you see something you’d like to comment on, please do.
The body will put this build right in the ballpark with the High Lift in terms of scale and actual measurements. The specs for the body are 18”L, 6.5”W, and 5 1/8”H. The wheelbase will be right at 12”, with an 8.25”- 8.5” track, depending. At this point, my plan is to run TLT axles, a Tamiya TA02 transmission, 1.9 rims (duh) and Losi Mini LST “Mini Claw” rubber, although that is subject to change.
I started with a cardboard mock up and went from there.
I started with 1/8” X 1” aluminum for the frame and went to drilling, cutting, filing, cussing, filing, measuring, cussing, filing, drilling, tapping, cussing, sanding and cussing. Anyway, I ended up here:
Same thing, different shot:
I thought about using steel, but decided against it. What’s more scale than a rig that can actually end up with a bent frame? Ahahaha…yeah….so…here is the frame, partially assembled with part of the cross members installed. This is just a rough assembly at this point, but it sits straight and flat and is already fairly rigid, even at this point with nothing tightened down too much.
To beef up the cross members, I’m using a brass sleeve that fits exactly over the 10-24 Allthread, then countersinking it 1/16" into the frame on both sides. I intend to solder the nuts on one side of the cross member, then Locktite the opposite side. That way, nothing’s permanent and I will still have the option to take the frame apart if I need to. Here are the brass sleeves inserted, along with the mounted tranny/motor plate bolted to the threaded frame. Everything is tightened up and we’re still straight and true.
That’s all I got for you guys for now. Let me know what you think. I’ll get some more shots, with the body, when I get further along. At this point, I’m thinking 4 link suspension all around, with some (God help me) TLT shocks. I’m not opposed to running leaf springs. In fact, I’m going to order some High Lift leafs from Tower and see if I like them, or if they will even work for this application. Thoughts?
