My creeper
I got some gmade spacers from ckrc. But they came in a junfac bag. So if you are looking for wheel spacers or hex in largers I would junfac.com. Hope this helps.
i mean as far as universal parts, shocks, wheels, drive lines and so forth. nothing specific to any particular make or model.
on the hexs - 12mm out side is standard, i think the shafts are larger on the creep, 6mm hole?? maybe?? And I would venture a guess that 8mm thick is about all you can do without running out of thread and having to do a widener kit.
Ok well I don't currently have plans to widen anything yet. I also plan on keeping the stock tires as I feel any added traction would just lead up to more broken parts.
I mocked up the stretched rear axle last night and it looked like a limo. So I have a new game plan. I am going to stretch the back out and shorten the front up some. It will still have a little stretch but only about 1/4" total if that.
Here is a pic of the new links I made today. Using all the creeper ends. The side plates were drilled for a new battery tray mounting position. The top links reference a stock upper link. Those are the front and rear uppers. The front uppers are stock length but rears are stretched out. If I have measured correctly I will be using the innermost top link hole on both ends of the side plates.
The bottom links are in reference to a stock lower link. The upper is a little shorter, the rear is quite a bit longer.
To test I am using an old severely beaten up stock front shaft I shortened up a bit. Those are paper clips in that thing holding it together. LoL
Still don't really know how I'm going to mount the rear shocks just yet but ill figure something out.
the way the spacers work is it replaces your hex and spaces out the wheel basically..but how you secure the wheel to the axle is by a barrel nut that screws onto the existing axle shaft(i think that is what you were curious about). the reason why someone would want the hex enlargers would be to fit some larger rims/wheels.
Thanks for filling me in on that. I don't see any larger tires for this as I feel all they will do is break more stuff.
I got my stretch on last night. I'll post up a pic later. It's not close to being done just yet as I have to re-hole the body as well as replace the side plates and battery mount. It will be ready by the weekend though.
I still have shock work as well as battery tray work to do but it will look similar to this when done.
The battery will fit into here. This is a venom 5000 mah 3S battery
I'm uploading a video of my creeper as I type this. Its got the 2800 Tazer Motor and the Tazer ESC. It can crawl/bounce with the 2S battery. It can bounce/race with the 3S battery. I broke the rear pinion right at the start. I replaced the pinion with one out of my old creeper and the old gear is a much better gear then the junk I got with this kit. The junk front one is holding on for now. This thing will turn cyclones very easily and I think its more of a FOFF vehicle with the 3S in it. I also broke an old driveshaft I patched together for the front.
What does the last 2 F's stand for in FOFF?
Formula Offroad ??
I will say this. Its fast...
Formula off, its just shortened, not an anagram.
Sent from my RM-845_nam_vzw_100 using Board Express
They will do you just fine! I haven't ever used them but run mips on mine.. nothing like the confidence of a metal drive shaft..
I ordered 1 set. I wanna see how they live in what I have now. After they have been run a bit I should be getting close to building the new truck.
Well, I took mine out broke the front shaft again. So I ran in 2wd. I beat on it quite hard with the 3S battery and all. It lived! I am actually impressed that it lived really. Jumping, bouncing, and lots of wheel spin trying to climb stuff. 2800KV motor too.
So I had a Gmade driveshaft. I cut it down and put it in place. This shaft is designed to be used on pinion shafts with the hole in them. The creeper outputs and axle inputs don't have this hole. I used set screws. It actually held up. I made it back to work and decided to try to help it a little so I made these rings that should help hold the set screws in place. If this shaft lives past the next ride, I will be happy. The rear is now a junfac and it held up just fine.
I used an old bronze bushing to make this. I looked for some steel but didn't have any. I figured this was better then nothing.
well that front shaft survived a 2S and 3S beating tonight. I think it will stay. I'm also impressed I didn't blow one of the axles out. I was jumping and bouncing under full throttle too. I am running the stock tires, they spin more then they bite so that may be why the stuff is living.
i ran those tires and wheels with no foams in the snow the other day on my Bronco, worked pretty good.
On the snow I can say yeahthey should work well, they also float well in sand too. I'm gonna call the 2 hills "bounty" hills. Although I did make them with the 2S battery it was just barely with 6-8 attempts. On 3S I did it in less attempts. I barrel rolled it, endoed it, and crashed it a bunch LOL. I will shoot some video of these climbs this weekend and should have a video up by sunday evening. I would say the climbs are about 10ft from bottom to top with leaves and loose dirt/sand as well as a few small ledges in them. I'll do my best to record it so the steepness is shown. I love full throttle assaults on hills!
