My Kamikaze Kustoms Zero/Berg build
The new Delrin side plate are holding up and working great.I also switched to Traxxas big bore shocks and that made a big improvement.
Joe, I have basically the same set-up as you, I was wondering what weight oil are you using in the Big Bores. If you don't mind sharing this:lol:. BTW Happy B'day8)
Thanks.
To start off if you are running the big bores you need to limit the shock about a 1/4 on the inside to shorten the shock. this will keep you from having to lay the shock down as far.
Second you need to run losi whites in the front and yellows in the rear.
Third try running 30wt in the front and 10wt in the rear. I am trying 30 in the rear now but I have not had a chance to run it enough to make the suggestion to run it yet. I know it works great in the rough stuff but I will be able to say if it works or not by Tuesday.
Sorry if this has already been asked, but have you tried mounting the battery up front over or next to the steering servo? Just wondered what impact this would have on CG.
Well I did not get the finish I was looking for at Nationals but I will take 6th place.I was tied for 5th with Austin Dunn and lost the tiebreaker that went off of course 4.
The Zero 3.5 worked great all day I just wish it would have had a better driver.
I would strongly recommend any of the Kamikaze Kustoms lineup of parts.
Next up a new Zero 4.0 build up"thumbsup"
6TH place Rccrawler 08 Nationals 2.2 Rig
Great job on both your finishes.Your one hell of a driver/competitor and great guy on top of that. Just watch out for them roving claymore mines.:lol: You're gonna like the 4.0
You were a great guy to hang out with! Look forward to seeing you again!
And he and Kami did look out for the claymore to my dismay:lol: That was funny. One of the highlights from my trip.
Way to go Joe and Tyler and SERCRC. Thanks to Jason and TCS and all of the supporting vendors!
this thing worked awesome all weekend. i can think of one tough break joe had that would have changed the outcome of the entire event.
congratulations on the finish's again
-Nabil
Here is my parts list
Kamikaze Kustoms ZERO chassis
Berg axles
45t v-11 motors
CC Sidewinder ESC
CC BEC
Hitec 5955 steering servo
Hitec micro servo for the dig
Two micro switches
Ax10 bent lower rear links
Ax10 straight lower front links
Traxxas revo pushrod #5319 rear upper links
Traxxas revo pushrod #5318 front upper links
Jp Customs 90 mm shocks
Losi white springs front
Losi yellow springs rear
Nuts and screws from the Berg kit
Panther tires
DX3R radio
Is this set-up still pretty much the same, other than the shocks?
