antonio_cadiz
me too. It does not roll thin. bad buy
I have these on there way to go inside the offset Pro44 housings. It seemed like a few people here had issues. Any new news on these working in or shims needed to dial? The last post from SSD was no shim, so I'm going to start there.
Also, and unrelated to the overdrive gears, I ordered the offset metal tubes with integrated link mounts for the front where these overdrive gears are going. I'm still trying to find out if plans for metal rear tubes with integrated link mounts are in the works or not.
I have now built two different SSD offset front axles - both with SSD Overdrive gears in them. One with has the Pro44 center diff housing, and the other has the Diamond Pro center diff housing. Both were a little notchy when I first built them, but with one shim on the outside of the housing between the driveshaft and pinion, it smoothed out quite a bit. I did not have to do any shimming of the ring gear. The shim on the outside of the diff housing helped pull the pinion out a little. While it is still not buttery smooth, they are breaking in, and getting a little better each time I run them.
I had very poor results trying to use SSD Overdrive gear sets in other brands of axles. I tried using them in my Capra, my Vanquish D44's, and also in a set of stock Axial AR44 axles. They were completely unusable in all three of these axles, and no amount of shimming of either the ring gear or pinion was able to make them work. I ended up buying a set of the new Axial overdrive gears (which now also use a 6-bolt locker - just like the SSD gear sets) and they worked perfectly in my Axial axles.
I have heard that Axial changed the design on their center diff housings a little, so maybe that's why the SSD gears aren't working well in other brands of axles.
I'm not sure if SSD has any plans to roll out machined aluminum metal rear tubes. The front axle tubes you have with the integrated link mounts were designed as upgrades for the plastic ones that come in the Trail King chassis kit. The rear axle tubes for the Trail King are plastic as well. Instead they sell brass weights for the rear axle: Trail King Pro44 Rear Axle Brass Weights They add 52 grams to each side of the axle.
If you don't mind adding your own link mounts to the rear axle, you could always go with the Pro44 rear axle - which has heavy metal (cast zinc) tubes. 100 grams for just the axle and diff (no internals). Pro44 Rear Axle Case for SCX10 II
Which rear axle housing are you running? If it uses a removeable pinion support, you can flip your ring gear to the other side and install the pinion support upside down so that it is low-pinion and it will spin the opposite direction. If you don't have a housing that is capable of this... get one. Definitely the easier/cheaper solution compared to a counter rotating transmission. You can build either front or rear axle that way.
I understood that... look at this: Diamond Pro Axle Case for SCX10 II then read my post again.
