Your tubes before were plastic or AL? How much did you lose?On the axle i received, the short side didnt have the indent cut out. I pmed him about it and he said it would be fixed. I realy think they should have the bottom hole drilled from the factory but not a huge deal. Weight savings was dissapointing for me. I was already running the gen 1 proto axles with the ultra light cases so i didnt save much at all. If you are running cast axles the difference would be huge.
I have been swamped building our new facility and havent even driven the truck. We are having a tuneup comp Saturday so I will get more info on how they work then.
Sent from my DROID RAZR using Tapatalk
Light weight aluminum cnc tubes:
Long tube 1 5/8 oz (44g)
Short tube 7/8 oz (26g)
I dont see the weight of the delrin rears listed in the thread, if I get motivated Ill pull mine off.
Long tube is 22g
Short is 14g
"thumbsup"
Im sitting at the first comp with the new tubes witg 2 bent rear axles... firat bent on a decent fall but the second bent on a fall of less than 1'. Ive got 2 machinest standing here and they are both blaming the flexability of the white delrin. You can actually see the tube flex when the truck is in a bind. I would highly recommend switching to either black delrin or nylon. I know from experience that the black does not flew like the white (even though its supposed to be the same).
I can tell you're using a touch screen! LoL
So they can be bent back right? Some flex is good if there is no breakage.
Thanks for the update!
