Post pics of your 2.2 Comp rigs and specs!
LOSI NIGHT CRAWLER
-LCC trans w/ MRC mini servo for dig
-LCC side plates lower links
-CF shock mounts
-LCC rear shocks w/ losi strike springs
-TRAXXAS big bore front shocks w/ internal springs
-momba max pro w/ novak balistic
-HB sedonas mounted on VP revolvers
-AXIAL shell w/ gunnar mounts
Axial AX10 ARTR
• Stock chassis modified for link placement
• 3/8" Delrin lowers, inboard
• Axial 55mm Alum. uppers
• Homebrew rear 4link plate
• LD Racing BTA, tierod drilled for Axial flange pipes as bearings
• GH Racing Alum. knuckles
• Inverted stock shocks, Axial whites modified with Losi 40wt oil
• 10mm fuel tubing internal and 5mm external
• Axial underdrive gears in rear axle
• HB Sedonas on Axial 8 Hole Beadlocks, 4oz per front, 2oz per rear
• PL 2 stage foams up front, un-cut
• Panther F400 foams in rear, un-cut
• Novak Rooster Crawler
• Integy 55t
• Spektrum SR300 Rx
• Spektrum DX3E Tx
• Futaba S9156 St. Servo, 340oz @ 6v
• Intellect 1600mah 2/3A pack
• Robitronic clamping servo horn
• Dubro HD Rod Ends w/ misalignment spacers
Sorry about the pic quality...the iPhone sucks for photos.
beetle juice v2
berg v1 axles
slw .7 front .5 nt rear
86 jeep steering
7950 hitek
white rovers
losi shocks
t1e rear links home brew fronts
fxr
custom panels with p-51 paint job
my sons rig
v3 beetle juice
v1 berg axles
v1 slw
rovers
losi shocks
ckrc steering
fxr
xr10
axial bent upper links
axial machined lower links
spektrum micro rx 3500
hobbico servo losi horn
cc bec
tekin fxr
punk dig switch
internal springs front shocks
holmes 45t motors
boss claws
gunnar body mounts
My first RC builds. Did a 2.2 sportsman crawler and a 1.9 rig. Both are axial based.
cant say to much but has a chump chassie 7950 servo some ti links 40 turn blits motors fxr and custom axels.i have 2 others and a xr10set about the same
Fawv Designs Berg
86Jeep steering
2x Integy 45t motors
tekin FXR
punk dig
hobbico steering servo
DX3E TX sr300 RX
VP Revolver wheels
HB Rover soft compound
Want to comp
Here is my rig.... I want to comp.
Here is my losi night crawler. I got it well used and stock. I have added hb rovers, novak goat 3s, savox servo, and axial wheels with a lot of weight. I just got a few parts in today to change and repair highly worn parts. I have a set of new axles, drivelines, and hd worms. Hopefully I get this up and running soon, so I can get a few new pics.
A pic before a few runs.
Torn down
A pic of the axles.
How do u like the 3s in the night Crawler? I'm running a tekin probrush system in mine thinking about going brushless. I would love some feedback
Sorry I do not come on here very often does not seem noob friendly. The goat is cool has lots of power, but does glitch. Mine does not glitch a whole lot. It did glitch like hell on a comp and I blew a gate it was annoying. My friend has one and it does the same thing. It really comes down to if you can live with it. Novak does warranty their stuff i know I messed up and they still fixed it. I have moved to a different rig now any ways I am running a xr10 and I may flip the night crawler into a scaler.
