RCCRAWLER tips, cheap tricks / parts guide.
BENDER
2006 2.2 National Champ
Moderator
Big Bear Lake
This is intended to be a guide to cheap fixes, mods, tricks, and parts. I'm doing this to keep a thread that just contains these tips so they are easy to find. I used title of original thread w/ a little editing on some. I included important tips on setting up chassis's as well.
First off...............nitros can't crawl.
KevKaos: April 2006
Got a cheap trick, that's not on list? Post it here....
Cheap tricks, post them here - RCCrawler
http://www.rccrawler.com/forum/axial-scx-10/387262-how-do-narrow-xr10-mod-axial-axles.html
Wide AXR10 axle mod
Painting the body (opinions on brands).
Painting the body - RCCrawler
Tips on painting bodies (correct way).
I need some tips on painting a proline body... - RCCrawler
Stripping paint from lexan.
stripping paint from lexan - RCCrawler
Lexan body work.
Lexan body work - RCCrawler
Ultimate tire foams.
Ultimate Tire Foams - RCCrawler
Removing glued tires.
Removing Glued Tires - RCCrawler
How to narrow 40 Series wheels
-Narrowing Proline 40 series wheels
-Narrowing Axial 40 series wheels
Cheap plastic rod end slop fix.
Cheap plastic rod end slop fix. - RCCrawler
BFT rod end part number and price.
BFT rod end part number? - RCCrawler
Traxxas rod end part number.
What is the part number of that standard Traxxas Rod End? - RCCrawler
Cheap metal rod end bible.
CHEAP METAL ROD END BIBLE - RCCrawler
How to lock Clod diffs.
RCCrawler.com- Your #1 source for Radio Controlled Rockcrawling!
Gear ratio equations and chart.
Gear Ratio Equation and Chart I Made for us Crawlers... - RCCrawler
Balancing weight.
Balancing Weight - RCCrawler
Adjusting anti-squat?
Adjusting anti-squat? - RCCrawler
Anti Squat and Suspension Tech - RCCrawler
another-4-link-thread
Torque twist (how to fight it).
Torque twist/HELP PLEEEEEEEEEEASE!!!!!!!! - RCCrawler
TXT servo mount dimensions.
Servo mount? - RCCrawler
Revo shafts (how to install).
I've seen lots of posts asking about Revo shafts... - RCCrawler
Extending Stampede driveshafts.
How to Pede sliders..Drive Shafts - RCCrawler
4 Link 101. (proper set-up tips)
4-Link 101? - RCCrawler
How to figure link length.
finding the correct suspension link length - RCCrawler
Making links.
Making Links - RCCrawler
"roller" links... - RCCrawler
Best way to link mount shocks.
What is the best way to link mount shocks? - RCCrawler
How do I stop my link clamps from sliding?
How do I stop my link clamps from sliding? - RCCrawler
How do I fishmouth brakeline?
how do i fish mouth a brakeline - RCCrawler
Harris safety silver-56 (where to buy).
harris safety-silv 56 - RCCrawler
Brazing stainless?
Brazing stainless - RCCrawler
Bending aluminium.
Need help bending aluminum - RCCrawler
Cutting aluminium.
What do you guys cut aluminum with? - RCCrawler
GD-600 (how to install).
Installed a GD-600 gear reduction - RCCrawler
Servo guide
R/C Sailplanes: Servo Chart
645mg turned into winch.
Crawler Tech: How to Build a Winch - RCCrawler
how do i turn a hi-tec 645MG into a working winch??? - RCCrawler
Correct part # for pinions.
Correct part numbers for pinions, etc? - RCCrawler
Servo saver or not.
Servo saver or not - RCCrawler
Truck problems (fixing glitching).
truck problems - RCCrawler
Tube project idea (getting scale look right).
tube project idea - RCCrawler
Series or parallel?
Series or Paralle - RCCrawler
Motor wiring (forward/reverse rotation Q's).
Motor wiring - RCCrawler
How to build/tune a 2.2 comp crawler.
2.2 TLT Competition Crawler Question... - RCCrawler
TLT Rock Buster vs TLT Max Climber (What's the difference?)
TLT Rockbuster, TLT Max Climber - RCCrawler
TLT tranny options.
TLT transmission options for your crawler - RCCrawler
Turning down TLT shocks, for a more scale look.
How to turn down stock tlt shocks. - RCCrawler
Limiting straps.
Limiting straps - RCCrawler
Fender trim materials.
Found a couple good fender materials... - RCCrawler
R/C License plates.
looking for rc sized replica license plates... - RCCrawler
Cheapest crawler.
ZipZap Rockcrawler - RCCrawler
Need some driving tips for comps? You know you do.
How to: Drive Better "TIPS" - RCCrawler
Tips for building a backyard rock garden.
How to build a crawling course: step-by-step - RCCrawler
How to make front dig.
Miniwheeler's dig
socket to ya dig
Bearing mod to eliminate the slop in worn aluminum axle C's
Mnster's mod
Locking a Pede tranny without epoxy or JBweld
Offroader5 shows you how to lock a pede tranny with no JB or goo
Widths of common crawling axles
Losi Springs to use on crawlers
Time to start wrenching. :twisted:
tltcrawlerxtrem said:
how to cut alumium link is wrong sumthing for maximizer beadlocks :?
Thanks for pointing that out, I removed link. I'll try and find the right thread and post it back up.
hcfr34 said:
Thanks for all the time you put into the stickies, what a truck load of helpful info. ;)
No problem, glad to see people are finding it useful.
Updated
OK guys, I finally updated these links to the new forum. LMK if anyone finds any problems.
i though i saw somewhere someone cutting a dog bone in two then like putting each half in some sort of a metal shaft thing
FASTENERS..........we all use them in the build-up of your rigs. I used to get mine at the local True Value, till I found this place.
www.microfasteners.com
Money back guarantee...can't beat that.
Great price. I just recieved my order of 120 SS sockethead 3mm screws, ranging from 20-40mm in lenght. $31 shipped. Half of what you would pay at the hardware store. That encluded 3 day priorty mail:mrgreen:
gear reduction units?
Can you put up sources to gear reduction units being used on the E/Tmaxx?
I can't find anything.....
is anything about how to made a tube chassis or roll cage?
like what material to use and how to weld it together,.
