scx10 body guide
Tamiya Tundra fits honcho wheelbase 12.3". Its very close. 1mm out as i found out. this is refering to the bed and cab by the way.
Cheers
T
the hilux is a bit narrow, other than that i believe it fits the dingo wb the clod buster is a bit on the short side. these too if anyone can verify for me it would be appreciated.
Pro-Line 1972 Chevy C-10 Clear Body 3251-00
Didn't see this one listed. It fits nice one my Bruiser chassis (11.5" wb) 1.9" rims with RC4WD Mud Thrashers on K44 axles and narrowed chassis. You will need to trim up the bottom of the cab to front of the bed by about 3/8" to make it look right with the wheels and chassis (clearance and looks).
Nice Thread "thumbsup"
thank you its listed under the dingo bodies. i only put part numbers on bodies with multiple listings. like that proline wrangler.
HPI 7182 Wrangler - 12.3" WB
Plus it's 8.25" wide, so it's good for those that like widened axles.
i am ordering a bronco body from hpi soon and was going to add those assuming they are all the same wheelbase. they seemed to be right around 11.8 though.
Tamiya highlux 11.5"
Tamiya bronco 10"
Tamiya s blackfoot aka f150 9 3/4"
Tamiya clod 10.5"
this list is ment for bodies that are a close fit and dont require any mods to teh wheelbase. though i may edit in another section for close bodies.
the 80 proline blazer is 11" WB
what about a f350 crew cab? i know thats custom,but can someone give me a ball park wheel base?
and again both blazers are listed on the first page. the cgr is a longer wheelbase. as far as the 350 goes, make your body then your links it is best not to assume anything. to many variables.
i was just throwing it out there that the non cgr blazer was shorter than prolines listed specs
added the priline f250. if anyone is wondering why i added it to the honcho list even though it is only the cab, honcho bodies built like that do not look right on a dingo wheelbase. the rear tires sit to close to the cab.
Does anyone know the wheel base for the hpi Ford svt raptor body? I have been looking for days and can not find anything.
Sent from my HTC One using Tapatalk
As a fyi the G6 rubicon has a in between wheelbase of the honcho/rubicon unlimited and the dingo. I think its somewhere around 12". Just thought I'd add to the confusion....lol!
I got two the Axial Classic Early 50's Gmc/Chevy Bodies that are 11.5 for short wheel base scx10 and a Proline International scout body that's 11.5 wheel base, and a Axial Ridgecrest body that's 12.5 wheel base
