microgoat
This is the second time this has happened to me, so it can't be a coincidence. I've got to be doing something wrong, but I can't figure out what.
My setup is:
Mamba-25
Outrunner, one Axi, one Park 400
Six cells in one rig, eight in the other
Same radio gear in both rigs, down to the transmitter.
Disabled BEC on the Mambas (removed red wire from the harness of a 3-inch extension (to keep programmability thru Castle Link), clipped switch from the circuit board and insulated the wires from one another).
Electronics on both rigs fed thru a tap on the 5th cell from each battery pack.
Here's the weird part. Both my Mambas have melted the connection between the servo extension and the Mamba ESC. The 8-cell rig actually smoked at this point, and I went back to running it on 6 cells. Obviously there's some voltage getting through, but where, and why?
On the 6-cell rig I eliminated the extension and everything's kosher now. Would eliminating the center wire from the extension at the ESC end help on the 8-cell rig (It's currently only clipped at the receiver end)? I can't imagine there's enough juice there to jump the gap, especially with the switch removed.
People run extra cells in Mambas all the time without melting them, so what am I doing wrong?
I could call Castle, but it's after hours, and you guys are pretty smart. Help a brushless brother out!
My setup is:
Mamba-25
