Eh...
A diode will allow current to flow in only one direction (forward biased). When you install the diode backwards (reverse biased) it can still allow current flow if you apply enough voltage. You'll usually get only milliamps of current through a reverse biased diode unless you buy a Zener, which is made to operate in reverse bias.
A cap, in that application, will charge and discharge due to the varying amounts of current that will be flowing through WTF1. It'd (in theory) block current flow through the servo leads but allow the effects of an AC signal (which would basically be variances in voltage due to fluctuations in current) to pass.
As the cap charges and discharges you'll end up seeing the cap discharge towards the positive lead on the RX through the RX...(it'd actually charge through the Mamba)
That cap will also discharge through the servo lead on the Mamba side, but that will be as a result of charging through the RX. :lol:
Just suck it up and use the RX pack. :lol:
