so many different jeeps, what's the difference?
so this is getting a bit off topic, but when does an axle become a 1 ton axle? what "rating" does a dana 44 have?
an axles come in different sizes and thicknesses and a bunch of stuff
if you're building a real rock crawler on a budget i'd get Dana 60's front and rear those are 1 tons axles
on my truck a have a Ford 9" in the rear and a dana 44 up front
i think the Ford 9" (if you get the right one) is stronger then a Dana 60
(i'm not 100% sure on that but i'm like 99.9378463%)
There are definitely better suited sites for this kind of info, www.randysringandpinion.com has all the tech info on any axle ever made, but I would say basically a axle is rated as a 1 ton when it came from a factory on a vehicle that was rated for 1 ton ( or more) of payload. The diameter of the ring gear really tells the story about how much weight an axle is really designed to deal with. For example, the ford 9" has a ring gear that is 9" in diameter, the Dana 60 in the rear of my F350 has a diameter of 10.5" so it can safely handle much more payload and power to move the payload.
There are other differences that come on a stronger axle such as a larger pinion gear, bigger bearings on everything that spins internally, larger diameter axle shafts, stronger axle housings, larger brake systems, ect..."thumbsup"
Actually, 1969 was the first year for the Blazer and the Dana 44 has been around since the Willys flat fenders roamed the earth. "thumbsup"
Well I had a '46 flatty with dana 30 in the rear with full floating hubs :) It might be a dana 27. I know it had a 25 in front. :)
Currie 9 " will be stronger than a stock dana 60. I have a Dana 60 in the front of my pickup. I would be a worried MOFO if I had a 9" in the front.
A real 1 ton pickup has a Dana 60 up front and a Dana 80 in the rear. all factory.
I love wheeling in my jeep 1953 m38 a1. It has a WB of 83 ". It has the stock 4 cylinder. It came with 5:38 front and back. I have a lot of fun with it. When the wheeling gets to bad. I pull my 1969 old yeller Rokon out. nothing stops a Rokon :)
ohh EPiC FAiL
Dont for get about the military jeeps. :)
Evan
