Spektrum DX5E 5th Channel???
LowIsuzu
Australia
Hi all.
I have a Spektrum dx5e which has a 5th channel which is Only a 2 way on/off switch.
i want to use it as 3way, forward, neutral, backward. (on/off/on)
i pulled it apart a fair while ago, noticing it only had 2 wires running to it. is there capacity on the PCB to solder the 3rd wire to convert to 3way?
i want to use this for winch control btw.
thanks
I dont think you can do that... If the PC board isnt made for that setup.. Its kind of hard to make it do that... Are you using all the other channels? You could Unhook the wires from the Potientometers on one of the sticks... and hook that up to a 3 pos switch.
would you be able to use the trim adjustments like that??
