@simp: Your welcome.
I finished up the battery tray and moved the battery. I started to buy a pre-made mount but that just didn't feel like it was staying in the cheap spirit of this build. I had to buy a sheet of metal ($4.87 @ the local hardware store) and used plastic card and parts I already had.
First I made me a little cardboard template.
Transferred that template to the sheet of metal.
Cut out with mounting holes drilled. The extra larger hole is just for aesthetics.
Bent up and ready to test mount it.
Test fitted. You can see the plastic card I used to make it use all four of the battery mounting holes. I could have made this out of metal but went with the card because it was a bit easier.
Painted up and ready to install.
Mounted up.
Mounted up with the batt. Downside is the battery almost touches the spur cover. So unless I flip the trans back to stock I will not be able to step up to a 3s, luckily I plan to stick with my 2s lipos. 8)
I haven't tried this out on the trail yet but on my work table it feels much more stable.
Next up will hopefully be links. According to the tracking numbers they came into New York this morning so now I am just waiting on Mr. Postman to get them to my house.
-Prime-
Mounted up.
-Prime-
