JeremyH
NOTICE! - If your using Dlux delrin tubes use only Axial brand C's. I learned the hard way.
What happened?
BTW, I like your rainbow colored sig. "thumbsup" :lol:
The part of the C that slides over the axle tube on the axial brand C's is solid and touches the tube all of the way around
Thankfully Goe (crawler13)
Crap! This whole time I thought his name was Geo! I had no idea it was Goe. Kinda weird to spell it with a G instead of a J.
I have a bunch of Axial brand C's here. All of them only have 4 contact points.
The VP ones look better as far as a contact patch. The only thing that I dont understand is why they didnt thread their holes that bot it on to the tube. That really weakens the design if youre going into Delrin.
Wouldnt they be too difficult to line up properly to not cause issues with threading the screw?
Also, those bolt holes could easily be stepped up to 4mm and tapped. Do you think the delrin tube would handle that size bolt well?
Naw, I meant on your delrin tubes....if you had the tube and hub tapped.Do you mean with an AX10 axle?
Ok, good. That's what I planned to do on my new tubes. BTW, my VP hubs were a nice tight fit on the new tubes....much tighter than my old metal tubes. Couple that with the 4 bolts per side and I dont think I'll have any troubles like I had before.I quickly figured out that putting screws in the top and bottom made it 1000x better.
