Thanks! I wanted to pick up a set of the Al Ti-Fighters after seeing yours but I wanted a couple features that I was unable to "exchange" for the standard parts they come with. By the time I added up the machining and parts swapping I wanted, they were no longer a good choice for me. I would have spent the money for basically the cases only. So that's why I'm putting in a ton of work and good materials into stock cases. I'm crossing my fingers that someone comes out with an aftermarket case that is slightly reconfigured to take advantage of the narrow gearset and allow enough room for a servo without cutting the tubes all up. I actually have an awesome stack of ideas for a case design but the two companies I approached want nothing to do with it so I'm going to save them for myself until I decide to have them made for myself or find the right company to "buy" my design to mass produce for everyone to enjoy.
If there are any business owners/workers with pull that are reading this and are serious about bringing an awesome Berg case design to market, please PM me. I am certain it will be worth your efforts for a LONG time to come!
For what it's worth, I was an accomplished automotive powertrain designer for the first part of my career so I am capable of producing a production ready design. The only reason I haven't tried to produce these components on my own is the lack of reasonable machining capabilities and no desire to take on the business responsibilities associated with being the middle man which also doesn't help the bottom line cost that I would like to target in order to make them as popular as they should be.
As a worst case scenario, I'm planning on buying a CNC vertical mill in the semi near future and If there isn't anything out there by then, I'll bring them to market on my own.
The fit and finish on this chassis isn't as impressive as the first. It seems as if the cutter is walking a lot while cutting. I'm sure it'll work fine but for the price, it's not what I would expect.
You have the driver side one hole forward from the pass side...
Gentlemen, please have some faith in the fact that I'm not your common forum retard.
Hell, i cut my 7950 with a dremel and a belt sander. Now that will make ya nervous:lmao::lmao:And just when I thought I was past the point of being nervous when machining something, I had to go and do this..... :lmao: :lmao: :lmao:
Almost done with the front axle- for now.
Like people keep trying to tell you... Look at this pic. (sorry it's in black and hard to see) See on the lower side how the edge of the spacer and the edge of the chassis are basically flush.... And than look on the top side it's not flush.... Also see that black line I drew it's basically parallel with the spacer at the back of the chassis but it's not parallel with the shock spacer.... You just need to admit you are wrong man...
The holes are slightly undersized and they will actually cut threads until they have been run through a few times... I think this is what you are experiencing.
I have since opened the holes up enough to get them to pass through perpendicular to the panel so this is no longer a topic for concern.
LOL
I was just going to ignore all of the people commenting about something they are completely missing the point on but you're comments made me decide to attempt to clarify things ONE last time.
If anyone commenting on this has yet to grasp the basic scope of my "cutter walking" comment and think that I'm mistaken, please read the following:
This has absolutely NOTHING to do with any part of the chassis except the main side plate and the doubled up section/extension for the rear chassis/shock support. There are a series of 5 holes that all fall concentric to one another through two different plates. If you somehow think the opposing side is a factor in this, stop thinking it. This has to do with two panels only. Now for the key factor that I am pointing out; these 5 holes that pass through two panels (with zero room for stack up considerations) do not line up properly to one another. After getting a bolt through with a tapered point, the angle the two holes being misaligned created is what you see in the picture. The spacer is just loosely threaded onto the remaining portion of the bolt hanging out and does not have ANYTHING to do with the root issue at all. Finally, the fastener on the opposing side, if there were one shown, would not point toward the spacer in a parallel fashion, it would also have the tip pointing forward like the one shown in the picture.
So, to clarify, if I'm ever wrong I will gladly own up to my mistake and provide a corrected statement. In this case, I'm not, everything I have said is correct.
so we are all good then"thumbsup"
