Chris_The_Battery_Man
im thinking of getting a lipo for my wraith my questions are.
what is the biggest mah rating i can get that will fit in the front?
what C rating do i want for the most run time? (do i want a higher C rating or lower C rating)?
can i charge the battery in the car or does it have to be out?
hard case or soft case which is better and why?
and based on all those question does anyone have any that they recommend? (like anyone the cheaper the better)
and i dont know if it matters but i have a 27t axial motor 84/17 gearing and a CC BEC everything else is stock as far as electronics.
any help would be nice thank you in advance
This is an article I wrote up a while back. Might be a little out dated as for the pricing these days, but there is good info there
http://www.rccrawler.com/forum/electronics/100901-few-crawler-battery-buying-tips.html
I have seen people fit around a 2000-2200mah pack up front. I recommend a 3S pack. The higher the C rating the better. I dont recommend charging in the car because if it happens to catch fire during the charge, then you will lose the car too lol. You dont need a hard case. Those are silly. Batteries can fail and puff, weather or not they are in a plastic case. The only benefit to one is it would help keeping something from puncturing the pack. In the 10 years I have been using lipos, I have never punctured one.
I see you were also asking about the 2S2p.... That is really nothing you need to worry about. The P stands for "parallel". Which basically means if a pack was a 2000mah 2S2P, it would have 2, 1000mah 2S packs in it, wired in parallel. This method is very out dated, and in my opinion dangerous. I havent seen anyone do that in quite some time. So disregard the 2P portion of it. It's ir-relevant these days. But if you happen to be looking at a pack that is a 2p, I wouldnt buy one"thumbsup"
