Tires, hard or soft
hurricanemitch
Emporia
Just got some Swamp dawgs for my clod basher and was wondering if I need the tires as soft as possible or harder.
I will just use the truck for running around the yard and playin in mudd since I have waterproofed it.
I have the full uncut foams so I can leave them, cut them, or run with out.
Whats your thoughts?
what chassis are you running, weight is a factor. If you're planning on mud I would not run foam because they get crazy heavy when water gets in there. I would modify them if your just going to do casual bashing, they'll be fine.
foam will get heavy, but i would say a stiffer tire would do better in the mud. not sure what would help tho, if you plug the hole, it wont hardly flex none, even that aint good, but its a way around takin the tires off and cleanin/changin foams.
