This has nothing to do with AX-10 but it goes down the same line as others...
Ever since I saw the way Erik made the D-Lux axles I was thinking that I could do something with the bully gears that Ia had around.
I never put it to paper (or should I say bits), but then I saw all of the custom gear boxes that are showing up and I thought "Damn it! Now I really have to do it!"
So...
This is what I was thinking...
And then to the laptop...
I calculated the gearing and, with the axial axles and a 12t pinion, should be similar to the bully v1 axles (+/- 39:1).
The box is a bit wider than the berg box that is out there because the bully gears are also bigger.
As it is,with 2mm plates, it's 19.6mm wide.
I was thinking about being able to mount the motor on both sides of the box (normal pinion on one side and bully pinion is I mount on the other side).
After this I will try to design a chassis around the box and for that I will try to do something different.
This is for me to do when I have time and patience so it will take some time.
Besides, I have no CNC or a lathe, and I need both to turn this to reality....
Now there's AX-10 boxes, xr-10, berg, rc4wd and, finally BULLY (at least on the computer....)
Any comments or ideas are very much welcome!
So...
