Hi All, I'm looking for a ESC for my new Clod crawler, and I've found a company in Spain that makes Torque control System ESC's specific for that car, do you thing it's a good idea to get it? Theoretically this TCS will help to crawl better, but I'll preffer the experts advice. These are the ESC specs and a vid that shows how it works.
ESC with T.C.S(Torque Control System).
Designed specifically to work in a Clod, due to its capacity to distribute the torque ( manually or automatically) between the front and back axis.
With the same features as the Typhoon model.
Manually it is controlled with the third channel of the radio.
Automatically(enabling the TCS jumper) the ESC reads the speed's differencebetween the 2 axes and will send more torque to the slow axis.
http://www.youtube.com/watch?v=u0s2epvrQ7U&eurl=http://personal.auna.com/alopezd/ING/Cuerpo.html
- Input Voltage (1.2VDC/cell) 6-7 cells
- On-Resist.–Fwd. 0.001 Ohm
- On-Resist.–Rev. 0.002 Ohm
- Rated Current–Fwd. 320 amps
- Rated Current–Rev. 160 amps
- Braking Current 160 amps
- Rev. Delay 0 - 2 Sec.
- BEC Voltage 5.5 volts DC
- BEC Current 5.0 amps
- PWM Frequency 1850 Hertz
