I just wanted to show you all this. It is not on the car anymore. I wanted the long arms setup but didnt want to spend $100.00 on it, so i started playing around with stuff from my spare parts and unused chassis's. Perhaps it is a start, and someone else may find somthing i didnt to bring it together, so in the end we could figure out a good long arm setup at minimum cost.
All the parts are from an HPI SPRINT 2.
on the right i have sprint arm, c-hub, knuckle and link.
It fits almost perfect, just needs a few spacers.
Here is the full front end, and its the same width as the stock setup.
So lets go into the issue with this mod. It needs a 35mm dogbone, which i cant find anywhere. 30mm and 40mm are available in most models. If someone can find the perfect CVD or dogbone to fit this, then we would be in the money...... Im just not going to start ordering a bunch of different ones to try out. Im restricted to what i have here. To make what i had here work, i had to remove the inside bearing and, put spacers on the axle.
So then i decided to make a custom hex to remove the shims. This worked out better, but ummph!
Another view from the back
And from the top, after adding 4/40 ball studs and RPM connectors.
Now if someone can find the perfect CVD to eliminate removing the bearing, or the need for the double hex/specers, we would be in business.
