RCAddiction
I am getting back into crawlers again and had been looking at various kits - i think this is the one i am going to go with.
I pre ordered a kit today. No delivery date yet, but 4 shops I emailed only 1 replied, so they got the order. I just want to build another kit and this looks a good one to do. No ideas yet on body or electrics atm.
Amain has it as next week. Feb 15th.
One UK shop has the stock date as 13th February. Don't know about the one I bought from, but should be the same.
I just need to look at motor, esc, servo, and possible upgrades. Suggestions anyone? I have a 1080 esc already.
Thanks. I will have to read a few threads I guess. Got SSD knuckles on order and have a suitable 550 or 540 motor. Finding upgrade stuff in the UK can be difficult. I might just create a list and order from RPP or somehere.
I have a suitable 550 or 540 motor.
I just wanted to add that the 550 size motor will limit your pinion options as the larger motor will eventually hit the crossmember when trying to get mesh when gearing down. A 540 should allow for more options.
Is possible to sand down the area where the motor will hit on the crossmember?
If you just need a little bit of space its likely to help. Though I'd probably use a box cutter/razor to get the bulk of the material.
I have plans to design a crossmember (for 3D printing) that doesn't sit so close to the motor once I get the SBK. I'm not even planning to use a 550, I just want to fill a void I see.
14T is the smallest I've heard fits, that was using a HH Trailmaster http://www.rccrawler.com/forum/hpi-venture/605915-venture-gearing.html#post5907462
